Window Noise ?
tux
Has anyone had a wind noise around the drivers window? The dealer replaced the weather strip no change then ajusted the door noise still there. It is hard for me to pin-point the exact spot.Also the drivers window fogs up below about -30c. The other windows are fine. If anyone has any suggestions on repairs you have had done i would like to hear about the fix.Will be taking it into the dealer in the next week. It's a 2012 QC.Thank's Tux.
65Bowtie
Mine is quiet as a mouse. I would suggest using smoke, talc, vapor... to determin where the air leak is coming from. It will be easier to diagnose and fix from there.
quietpeen
2021 TRX
Hellcat
Go back to the dealer. It's under warranty
T
tux
I have been back to the dealer twice with no luck. And where i live it's a bit of a pain to drive in to get no results. I was just woundering if someone else had a similar problem and what the fix was.
jlc41
Miisiisippi via NJ, NY
v8
What 65bowtie said. Run your blower motor on high, then from the outside go around with soapy water in a spray bottle and squirt your doors and windows see if you get air bubbles that'll be your leak. Hope this helps.
T
tux
Hey Guys thank's for the great tips. I never thought of trying this. I will try it. But i may have to wait for a warm spell at -25c-30c ice does not bubble. ha ha. Thank's again Tux.
