That called belt line trim. I replaced them on my 06, the trim on my 13 still looks pretty decent though, but the roof seam trim needs replacing. I'm in FL. We get that alot here, especially on the coast.My 2013 Ram 1500 lower window molding trim has bulged. We live in a hot climate, so I think it's heat caused. Is there anything I can do about it instead of a dealer fix?
Those are attached to the existing belt moulding via 3M tape, if yours are already deformed then these will be of no use. When I had my ‘17 I replaced them with the OEM ones from the Lonestar Silver Edition.Only fix is to buy chrome window molds. Those don’t warp. I can’t bring myself to install chrome molds though. If I can find polished aluminum ones I’ll go that route
Edit: as a matter of fact this one is listed as polished stainless. Here
Didn’t see that. Thank you. Was doing a quick look through.Those are attached to the existing belt moulding via 3M tape, if yours are already deformed then these will be of no use. When I had my ‘17 I replaced them with the OEM ones from the Lonestar Silver Edition.
