window trouble
02 Ram
Nashville TN, soon back to IL
2005 NSRT-4
2.4L Turbo
my window doesnt go all the way up. i had the door panel off and everything looks fine. the X bracket that controls it looks OK but i can push up on it and the window goes all the way up, but it falls down after i let go. what could be causing the problem? window motor works fine up and down. TIA
HemiBabe
DFW
bump for you, hopefully someone can chime in
ercmesser
Tampa, Fl
I can't remember how our windows are, but look at the teeth on the drive gears and see if some are missing or partially there. If so you need a new one, LMC Trucks got them.
02 Ram
2005 NSRT-4
2.4L Turbo
thanks for the reply. its not gears, its a metal bracket, like an "X". i was told the regulator is bad and needs to be replaced
02 Ram
2005 NSRT-4
2.4L Turbo
anyone have anything good or bad to say about TYC regulators and power window motors? found one cheaper than the part stores
joshhhh
