Wire tuck?
Spsully
Anyone done a wire tuck? I just jumped off the deep end and started cutting all my connectors off the harness. Show me your hidden wires for inspiration while I try to get this done before the guys in wire coats come to get me.
Spsully
Spsully
Here is a couple wiring tips for anyone reading
1 label any wires you cut with two identical tags and cut between them. I'm over 50 connections and counting on this project. No way would I keep them straight and matching up the wires would be a NIGHTMARE.
2. Don't cut the wires the same length. When you solder everything back together, the harness will look like a snake trying to swallow an elephant. Space them out a little and it will go back into loom much nicer. It also makes it much more difficult for stripped wires to touch if you don't quite seal them off 100%
Spsully
Spsully
Here is the link to my build thread that has details on my wire tuck progress.
Build thread
geneseedennis
