Wiring issues
Yotaboy88
5.9 cummins
OK so I just picked up a 2006 ram 2500 with the cummins and an auto in it on the way home the speedo the oil pressure and the temp gauges just shut off hit a bump they come back on then the turn signal will work occasionally if moved just right other wise it will activate the opposite direction then last of all the navigation screen and controls will work randomly and ideas on how to fix any of these or where to start?
Y
Yotaboy88
5.9 cummins
Any help at all would be a huge help
drkmtr
Copperas Cove, TX
Sounds like something in the steering column. If the ignition signal wire doesn't keep a signal to the computer, it will think the accessories and guages need to be shut off, this is provided that I have that system understood correctly. All these new vehicles dashes are computer controlled and rely on signal wires to tell the computer what to turn on and off. Check the wiring to and in your column to see if something is worn or rubbing a ground.
