Hydrasport23
That tire cannot be properly repaired as that damage is considered in the sidewall. A tire can be repaired when using the correct patch and procedure but not outside of the major tread grooves. A major tread groove is one that has the wear bars in them. The damage is outside of the major tread groove. But, as some have stated, put a plug in it and roll. What can happen if the belts in that area start to rust or has damage or that area of the tire is "bruised" and it fails at highway speed? Maybe you get a warning of a tire problem, maybe not, maybe just a little fender damage or maybe a major crash. There is a reason the USTMA and tire manufacturers set standards for tire repairs. It is to protect you and those around you on the nations roadways. Pay for a new tire and get the road hazard warranty. Patch it and use it as a spare if your spare is a 2014.
