Zf8hp70 questions
Daveuk
Uk
So I have a 2013 ram 1500 4x4 hemi with a zf8hp70 im wanting to remove transmission thermostat housing and pre heater and go direct from casing into an after market thermostat and then to cooler
Question is im struggling to determine what fittings I need to c9nnect a 10an braided lines directly to the housing does anyone know of an adapter or what I can use please many thanks
If you remove the thermostat housing,you'll have to tap the transmission case for threads. I'd leave it attached to the transmission,cut and bubble flare the steel lines and stick a hose onto the cut steel lines. Just use transmission cooler combatiable hose . Post #264 shows the holes you'd have to tap and thread for a A/N fitting if you wanted to delete the thermostat housing. @DILLIGAF has a post up where he tapped the transmission case for A/N fittings
D
Daveuk
Uk
Thank you
Reticle918
