Zone 6" lift question
Jeffy
I'm new to the forum anim sure my question has been answered elsewhere, I just haven't found the answer I was lookin for. I've got an 06 trx4 that I'm planning on putting a zone 6" lift on pretty soon, my question is will this lift level my truck out? I know that the kit is a 6" front and 4" in the rear so naturally it's gonna be more level than it is stock. But I've noticed that a lot of people are installing bilstein 5100s along with the lift to get more height in the front. Will my truck set level with the lift alone, or would it be a good idea to install the bilsteins especially since the front end will be tore apart anyways. And if I should install them too, what setting should I put em on? Any pictures would make a great addition. Thanks in advance guys!
blackbeautyhemi
Lewistown, PA
It'll be pretty close to level but you might as well put the bilsteins on to make it level since its tore apart and gonna need aligned anyway. Plus you'll have fresh struts for a nice ride after the lift
blackbeautyhemi
Lewistown, PA
Mine are on the stock setting and it sits level. All depends on how high ya wanna go and if you wanna add anything to the rear
J
Jeffy
Thanks for the quick response! Yea I get where your comin from, I'm better off to go ahead an put em on there since its tore apart anyways. An like you said it'll give a better ride after the lift, the back will have new shocks so the new struts up front will finish it all off. By the way, you got a sharp truck man! I know I'm gonna go with the 35x12.50s and I have the wheel picked out I want but I'm stuck between 18s an 20s lol I can't decide if I want the look of havin a little more sidewall like the 18 will give me or just go with the 20s
blackbeautyhemi
Lewistown, PA
Thanks bud! Yea that was a tough choice for me to but I like the look of more sidewall and it gives ya more room for bumping a rock or curb without hitting your wheel if that would happen
Knotts89
Montvale, Va
I have 20s and i wish i would have gotten 18s. The tires are a good bit cheaper for 18s
