Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 1st Gen : 1981 - 1993 > Exterior
Exterior
Something weird with turn signal
This is a discussion on Something weird with turn signal within the Exterior forums, part of the 1st Gen : 1981 - 1993 category!
Originally Posted by crazzywolfie the switch is not likely the issue. your issue is still probably still under the hood ...
Sponsored By: BAK Factory Outlet
Reply
Old 09-12-2015, 09:26 AM   #11 (permalink)
The War Wagon's Avatar
Ram Year: 1992
Engine: 318 Magnum
Send a message via Yahoo to The War Wagon
Exclamation
Originally Posted by crazzywolfie View Post
the switch is not likely the issue. your issue is still probably still under the hood in the wiring or connectors. somewhere power is getting from the park lights into the turn signal light system
This. I've had some insulation rub away on socket wires, and a little duct tape fixed that (electrical tape exposed to the elements rarely stays put). I also had to clean out a turn signal socket with some steel wool, to remove the corrosion, and make a good contact.
The front end of our RC's catch/caught a LOTTA salt in the face back in the day, so don't be surprised to find worn insulation and corroded sockets that will take a Dodge SHERLOCK to track down. My horn wiring is practically shot, and needs to be redone next.
Sponsored Ad
Register to remove this ad.
__________________
"Me & my RC - me & my RC!!!"
The War Wagon is offline   Reply With Quote
Old 09-15-2015, 10:12 PM   #12 (permalink)
Ram Year: 1985
Engine: LA 318
Default
Yeah my horn wiring is virtually non-existant. The turn/parking connectors are completely and utterly screwed. They are only half there. So I'll get ahold of my parts guy for some new
Blue Chaos is offline   Reply With Quote
Old 09-16-2015, 11:47 AM   #13 (permalink)
crazzywolfie's Avatar
Ram Year: 81 93
Engine: 5.2
Default
ya if the connectors are toast you are probably best to just remove them and connect new light sockets straight to the wiring an use some dual wall heat shrink tubing to seal it all up
__________________
81 dodge d150 custom long box 318 670CFM Holley Street Avenger Carb
89 RamCharger 4x4 318/727/3.21 on 33's
93 ramcharger 318 FI 2wd
crazzywolfie is online now   Reply With Quote
Old 09-17-2015, 03:52 PM   #14 (permalink)
Ram Year: 1985
Engine: LA 318
Default
Put in new sockets on all for corners. Fixed some of the problems. Traced the wires and found one of the grounds was broken. Fixed that and they all work perfectly now! I think I will write up a how to with pics. I took a lot lol
Old 09-17-2015, 05:24 PM   #15 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
that is good to hear. a bad ground would have also cause the issue but not really as common to think of. usually it should have also cause other issues like the 1 headlight to be a bit dimmer or something since the headlights would share a ground with the turn signal but i guess the old sockets could have also been part of the issue.
__________________
Old 09-17-2015, 10:05 PM   #16 (permalink)
Ram Year: 1985
Engine: LA 318
Default
Here is one of the sockets haha
Old 09-17-2015, 10:09 PM   #17 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
seen that before. my 91 was like that on all sockets. i don't think my 81 was that bad but i think i ended up replacing all the sockets on it just because they were not looking great.
__________________
Old 09-18-2015, 01:09 AM   #18 (permalink)
Ram Year: 1985
Engine: LA 318
Default
My driver side front and rear looked like this but the passenger side wasn't bad but I replaced them anyways. This was the rear one lol the wings completely rusted off lol
Old 09-19-2015, 04:36 AM   #19 (permalink)
Ram Year: 81 93
Engine: 5.2
Default
ya not too surprising. i think i actually have or had a light socket with less than less than that left of it. on my 91 the previous owner had just taped the sockets into the housing. also i don't know if you replaced the reverse light sockets or not but when i did i used turn signal sockets so that i would only have to keep 1157 bulbs on hand instead of having to keep a couple 1156 bulbs kicking around.
__________________
Old 09-19-2015, 06:53 PM   #20 (permalink)
Ram Year: 1985
Engine: LA 318
Default
I thought about it. But I am out of cash lol. The three wire (1157) sockets were actually cheaper than the two wire (1156) sockets. I may go that route.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
turn signal help milldew1963 General Discussion 0 08-18-2015 06:40 AM
LED Turn Signal Help Aluminum Tech Info 1 04-28-2015 06:00 PM
Turn signal LED toppyw Exterior 8 03-05-2015 01:49 PM
Please help with led turn signal Drc1340 Exterior 0 12-08-2014 10:26 PM
turn signal justintimemoto Audio & Electronics 3 03-27-2014 04:46 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
