CV upgrades
TylerFT
GR, Michigan
My front left axle seems to click when I'm braking or turning. There's a new wheel bearing in that corner and there's no growling sound so I doubt it's that. I'd assume that it's coming from the CV axle and it doesn't shock me since it's just over 93k miles and I leveled it about 6k ago.
Any way, pretty sure I at least need to replace that one. My question is what are some good upgrades or are the OEM Mopar parts the best?
kg93
AZ
unless you want to spend some money oem are the only way to go.
If you can source Kore High angle cv joints those are a good option. 800ish new.
Other than that a company like RCV. They are custom cv shafts so you're looking at 2 grand on the low end.
T
TylerFT
GR, Michigan
Good enough. OEM it is. [emoji23]
