ABS/E-brake light
tim johnson
Gallatin, TN
On my 04 these lights stay on all the time. I had to take it back to the dealer to have the outside temperature fixed from where they put a PCM in it. I had them investigate, they tell me that I need a ABS module and the wiring connector going to said module. The wiring has gotten hot and some of it is bare. They also tell me that the connector is no longer available and they would have to put a harness in it. $2300 total for the repair. The service advisor told me that if I could find a connector at a salvage yard they could splice it and replace the module for $478.00. Anyone else had a similar experience?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Im not sure if that modual has a test that needs to be done after its replaced or not. If not you could splice a new connection with the new modual if your good with wiring.
Jems007
