Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Exterior
Exterior
LED Tail Lights
This is a discussion on LED Tail Lights within the Exterior forums, part of the 3rd Gen : 2002 - 2008 category!
I'm curious about putting LED lights in my tail light housing for tail/brake/turn lights. I know there are pre-assembled light ...
Like Tree1Likes
  • 1 Post By Lil_Ram
Sponsored By: BAK Factory Outlet
Reply
Old 11-20-2016, 07:58 PM   #1 (permalink)
Ram Year: 2006
Engine: Hemi 5.7
Default LED Tail Lights
I'm curious about putting LED lights in my tail light housing for tail/brake/turn lights. I know there are pre-assembled light housing one can buy. However, can one just buy the LED bulbs and put in?
Sponsored Ad
Register to remove this ad.
cuevrojamez is offline   Reply With Quote
Old 11-20-2016, 09:09 PM   #2 (permalink)
OnSale's Avatar
Ram Year: 2012
Engine: Hemi 5.7L
Default
Do you mean just buy a replacement bulb in the form of LED? Like the kind they sell at Pepboys? If so, yes and no. Yes it will work, no because it will hyperblink like you have a bulb out and on some trucks the bulb out light goes on. In order for you to get the hyperblinking to stop, you would have to cut and splice in a resistor into each bulbs wire.
Your better off buying a set of LED taillights off ebay. You can get the kind that look OEM, with red lenses and clear for reverse. They look oem but have led bulbs. I think they run around $120.
OnSale is offline   Reply With Quote
Old 11-20-2016, 09:48 PM   #3 (permalink)
derekp's Avatar
Ram Year: 2007
Engine: 1990 5.9 Cummins
Default
I would recommend the above. The bulbs alone cost about $20 each and you need 4 of them. With the resistors added you're looking at close to $100 already in parts. You would save yourself a lot of headache and time by just ordering the led tails off of ebay. I have a set of black housing ones and I love mine.
derekp is online now   Reply With Quote
Old 11-20-2016, 11:41 PM   #4 (permalink)
blackbeautyhemi's Avatar
Ram Year: 2006
Engine: 5.7 HEMI
Default
Sylvania makes a good led bulb replacement but you'd have to wire in a resistor for the turn signals. Which it really isn't hard to wire in the resistor at all. Only takes a few extra minutes.
__________________
*December 2014 TOTM Winner* 6" RCX, Bilstein 5100's, 35" Toyo open country mt, 18" Fuel Kranks, LSD 3.92 gears, SRT hood scoop, 20% tinted windows/drop tint, K&N CAI, throttle body spacer, Diablosport w/ hemifever 93 tune, 180* stat, true dual cherrybomb extremes w/ x pipe, high flow cats, black headlights, LED tail lights/3rd brake light, rhino liner, tri-fold tonneau cover
blackbeautyhemi is offline   Reply With Quote
Old 12-13-2016, 07:26 PM   #5 (permalink)
Ram Year: 2004
Engine: Hemi 5.7
Default
I HIGHLY disagree. I was just searching around here seeing what others are saying, and the taillights are a, waste of time! I ordered a set of led taillights (that said were plug n play and had load resistors in them)..THAT WAS FALSE. they worked when they wanted to, sometimes I had to knock one to get it to work, and other problems along with the lamp out being on all the time..I ordered led bulbs off amazon ($60 total, 4 red 2 white), and load resistors I can get anywhere. WAYYYY cheaper than that other junk, and if you know what your doing, than do it.
blackout514 is offline   Reply With Quote
Old 12-13-2016, 08:45 PM   #6 (permalink)
Ram Year: 2002
Engine: 5.9 Magnum
Default
I have a set of sonar (knockoff recon) led lights. The full set and I've had them for a couple years now without any problems.
korby05 is offline   Reply With Quote
Old 12-13-2016, 11:52 PM   #7 (permalink)
Ram Year: 2006
Engine: 5.7 HEMI
Default
I've had a eBay set in my truck for 6 years now and they work perfectly fine since the day I installed them.
__________________
Old 12-21-2016, 11:33 AM   #8 (permalink)
Ram Year: 2004
Engine: Hemi 5.7
Default
well thats good for you guys. i dont trust ebay really. but i returned those junks ones i had, and ordered LED bulbs for the rear. i recently installed a tailgate bar which looks great, and i only have reverse LED in for now. they work with no problems, they are plug and play. i know you have to wire in resistors to prevent hyperflash and prevent the "lamp out" message..do i have to wire in resistors for each bulb, making a total of 4 resistors (2 turns and 2 brake bulbs)?
Old 12-22-2016, 03:08 PM   #9 (permalink)
Lil_Ram's Avatar
Ram Year: 2003
Engine: Power tech 3.7L
Default
If curious I've got a brand new set I need to sell ordered 2 sets on accident.
usaf2006 likes this.
__________________
3.7l
35s on 18
7in lift
CAI
Lil_Ram is offline   Reply With Quote
Old 01-08-2017, 12:28 AM   #10 (permalink)
OnSale's Avatar
Ram Year: 2012
Engine: Hemi 5.7L
Default
How much do you want for them and are they for trucks with oem incandescent or trucks with oem led?
PM me and we can talk from there. Thanks.
Sent from hell via TapATalk
__________________
12' RAM 1500 RCSB ST - K&N 63 Series - Flowmasters Dual Exhaust - Black Chrome Clads - Lund Tri-Fold Tonneau - Phillips CrystalVision 9145 Fogs - Clazzio Custom Black Leather - OEM 1500 Fender Flares - 20% Tint All Around + more...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
New Spyder Auto Black LED Tail Lights for 13-16 Rams w/ OEM LED Tail Lights PNUTLT1 For Sale 2 06-22-2016 03:05 AM
Geno's Garage May Special - Save 10% on Headlights, Tail Lights and Fog Lights Geno's Garage Geno's Garage 0 05-01-2015 11:52 AM
tying fog lights into running lights or tail lights *tim* Exterior 0 11-22-2014 08:15 AM
3rd Gen OEM Professionally tinted tail lights, Stock tail lights, & Hitch step JStrag3 For Sale 7 03-04-2013 05:53 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
