Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 3rd Gen : 2002 - 2008 > Tech Info
Tech Info
3rd Gen Technical Service Bulletins
This is a discussion on 3rd Gen Technical Service Bulletins within the Tech Info forums, part of the 3rd Gen : 2002 - 2008 category!
Service bulletin #: 2022 replacement sb#: Nhtsa item #: 10000444 date: 20021126 failing component: 103700 power train:automatic transmission:torque converter make: ...
Like Tree1Likes
Closed Thread
Old 11-10-2010, 07:13 PM   #11 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 2022: Torque converter drain back valve
replacement sb#:
date: 20021126
make: Dodge
model: Ram
year: 2003
date created: 20030227
description of summary: The transmission may overheat due to a restriction in the torque converter drain back valve. *tt
Sponsored Ad
Register to remove this ad.
__________________
Owner & Service Manuals for many years: www.scribd.com/lilfroger/shelf
lilfroger is offline
Old 11-10-2010, 07:15 PM   #12 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 1400502: Fuel filter/water separator drain
Service bulletin #: 1400502
replacement sb#:
Nhtsa item #: 10000447
date: 20021108
failing component: 070000 fuel system, gasoline
make: Dodge
model: Ram pickup
year: 2003
description of summary: Fuel filter/water separator drain valve restriction. *tt
__________________
Old 11-10-2010, 07:16 PM   #13 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 1803502: Code p2181 - cooling system performance
Service bulletin #: 1803502
replacement sb#:
Nhtsa item #: 10000449
date: 20021129
failing component: 061000 engine and engine cooling:engine
make: Dodge
model: Ram pickup
year: 2003
description of summary: Engine throttle control light illumination and / or malfunction indicator light illumination with diagnostic trouble code p2181 - cooling system performance. *tt
__________________
Old 11-10-2010, 07:17 PM   #14 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 2024: Sticking pressure sensor transducer
Service bulletin #: 2024
replacement sb#:
Nhtsa item #: 10000620
date: 20021111
failing component: 103000 power train:automatic transmission
make: Dodge
model: Ram
year: 2003
date created: 20030325
description of summary: Harsh shifts due to a sticking pressure sensor transducer. *tt
__________________
Old 11-10-2010, 07:19 PM   #15 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 2026: Torque converter drain back valve
Service bulletin #: 2026
replacement sb#:
Nhtsa item #: 10000830
date: 20021220
make: Dodge
model: Ram
year: 2003
date created: 20030401
__________________
Old 11-10-2010, 07:20 PM   #16 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 33: Torque converter drain back valve
Service bulletin #: 33
replacement sb#: 222
nhtsa item #: 10000834
date: 20021201
make: Dodge
model: Ram pickup
year: 2003
description of summary: Customer satisfaction notification - torque converter drain back valve. *tt
__________________
Old 11-10-2010, 07:21 PM   #17 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 1: 3/8" torque converter drain back valve
replacement sb#:
Nhtsa item #: 10000913
date: 20030101
make: Dodge
model: Ram pickup
year: 2003
date created: 20030403
description of summary: Customer satisfaction notification - 3/8" torque converter drain back valve. *tt
__________________
Old 11-10-2010, 07:22 PM   #18 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 02026a: Restriction in the torque converter drain back valve
Service bulletin #: 02026a
replacement sb#:
Nhtsa item #: 10000914
date: 20030116
make: Dodge
model: Ram
year: 2003
description of summary: The transmission may overheat due to a restriction in the torque converter drain back valve and may cause damage to the transmission. *tt
__________________
Old 11-10-2010, 07:23 PM   #19 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 1800503: Transmission shift/speed control improvements
Service bulletin #: 1800503
replacement sb#:
Nhtsa item #: 10001176
date: 20030307
failing component: 180000 vehicle speed control
make: Dodge
model: Ram pickup
year: 2003
date created: 20030417
description of summary: Transmission shift/speed control improvements. *jb
__________________
Old 11-10-2010, 07:24 PM   #20 (permalink)
Ram Year: 2006
Engine: 5.9 CTD
Default Tsb 800703: Accessory drive belt squeal
Service bulletin #: 800703
replacement sb#:
Nhtsa item #: 10001518
date: 20030404
failing component: 061110 engine and engine cooling:engine:gasoline:belts and associated pulleys
make: Dodge
model: Ram
year: 2003
date created: 20030605
description of summary: Replacement of the alternator support bracket for accessory drive belt squeal. *tt
__________________
Closed Thread
Bookmarks
Tags
dodge ram tsb's, ram codes, ram tsb's, trouble codes
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2nd Gen Service Manual Bigtman07 2nd Gen DIY 1 05-24-2011 02:30 PM
4th Gen Technical Service Bulletins lilfroger Tech Info 11 11-08-2010 04:00 PM
2003 Ram Service Manual Bigtman07 Tech Info 11 10-22-2010 05:05 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
