Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
I just got mine back from the dealer for the same problem. Mine reads about 8 degrees colder than it actually is. They said they installed an update and it should fix the problem. It didn't.
Most of the time, mine indicates around 7-8 degrees colder than actual air temp. BUT- every-so-often, it is within a degree. Nothing consistent about when it reads close to right. Doesn't sound like anyone has found a real solution..
Thanks for the replies and I will try to get it in also and get on record. After almost 6,000 miles this is the only thing that I've noticed that isn't right.
