1998 1500 4" lift shocks
Atlas_3
1998 Ram 1500 Laramie 4x4
I am wondering if stock 3/4 ton shocks will be long enough to replace stock 1/2 ton shocks on a truck with a 4 inch lift
A
Atlas_3
Do you know where I can find them? I checked ranch they only carry up to 3 for the front
mitchbowers
Ohio
1996 2500 5-speed, soon to be leveled on 33's
5.9 Magnum
do not just get 3/4 ton shocks. You could go from whoever made your lift, or bilstiens/ fox if you have the money. Just make sure you let them know when you order them that you need longer ones to account for your lift.
Merc225hp
NA
truck
gas
They are out there did you check sj they should have them or top gun cutomz?
A
Atlas_3
I found some sky jacker nitro 8000s made for 4"-5" front and 1"-5" rear. Probably going to go with those
JustinRam1500
