2012 ram Express Lighting Question
brc80
Hi guys, I am new to the board so please forgive me is this is answered somewhere else.
I just purchased a 2012 Express with the single headlights. I would like to convert to a HID setup. Is there someone out there who makes a single projector kit? Or can i convert to the quad setup?
Thanks
WhiteExpress
Midland, TX
You can purchase the parts to retro fit a HID projector into your dual housings.
I did this, it's a lot of work.
You can also contact "The RetroShop" (a site sponsor) and get a quote from him.
He can set you up with either duals or quads. I personally like the look of a retro'd dual.
MADDOG
Out Exploring Arizona
I say contact the RetroShop.
B
brc80
Just to clarify, what i have on the Express are referred to a dual's? And the trucks with separate high and low beam headlight are quads?
Thanks
B
brc80
Thanks a bunch. Looking at the RetroShop now, they seem like they are the way to go. I was unaware i could do my fogs as well.
B
brc80
Are there any advantages to going with a quad setup over a dual? Or is the work the go quad not worth it?
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
my hid sense was ringin'!
Here's the pro's and cons of the duals / quads - for YOUR application (a truck that came with duals):
Duals - will retain bixenon capabilities from the projector. Lots of shrouds fit in your headlights (the shroud is the part that covers the projector). Doesn't have to be "cut" to fit, so - cheaper.
Quads - will fit, but you will not have bixenon HIDs from the projectors, as the lows will go off (if the lows go off, HIDs go off) when you hit the high beams. Some like the look of the quads over duals. I have ran both on my truck...........I love 'em both!
Hit me up with any questions you have!
I'll be logged into the chat feature of my website tonight as well (during Game 2 of the NLCS!). :D
B
brc80
So looking at the RetroShop's website, it looks like i have some choices to make. Any experience 35W vs 55W?
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
I'll say this.........
I have 4 kits that I sell. 65% go with the 55W kits, 20% go with Nightvision, 12.5% Economy, 2.5% 35W kits.
30-40% more light on the 55W kit. :D
B
brc80
Jj, thanks for all your help on this. I am thinking of going with these "http://shop.retroshop.us/ProductDetails.asp?ProductCode=4G%2EQD%2ERETRO"
in 55W 5000k. So Both my high and low beam will be HID correct?
4x4Hemi
Edmonton, Alberta
that just takes you to quad headlights haha if their bixenon h13's that means it HID high low
B
brc80
I was also thinking of going with the Fog-light upgrade as well. Is 55W too much for fogs? And can i get fog's in 3000k range?
Thanks again.
B
brc80
So the retrofit kit for dual's will eliminate my high beams?
4x4Hemi
Edmonton, Alberta
Are you wanting to order a whole new quad headlight to replace your duals? if you do that then yes, it will eliminate your duals, but projectors and HIDs will be a million times better then what you have now
4x4Hemi
Edmonton, Alberta
It doesn't show all the optiOns you chose but I'm assuming the 55w hids right??? That will all work beautifully I'm sure. And of course your highs and lows will work. Good choice
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
bingo. go with the dual lights, retro'd and you'll keep your highs. :D
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
Retro FTW!
