2014 ram 5.7 spark plug replacement
PRRAM
2014 Laramie Limited
Overall not a tough job just tedious to remove and replace the driver side closest to the firewall.
Plugs are IRIDIUM NGK so use IRIDIUM NGK, good luck finding aftermarket IRIDIUM NGK isn’t happening these days. Also for you old timers don’t put Anti Seize on you plug threads. :roflsquared: I torqued the plugs to 13 FT LBS but for the rear you can’t so after you torque a plug get a feel for how much pressure is applied with a 3/8 ratchet and use the same force. Clean the elec connectors on the Coils with CRC Electrical Cleaner. On the end of the coils use dielectric grease AKA bulb grease. I replace mind at 75K miles you can easily get 100K out of these plugs from factory. I won’t change mine again until 200K. Dont use Champion plugs use NGK!!
1) Disconnect battery
2) Pull black cover off
3) Disconnect Sensor cable on the throttle body connected to intake
4) Remove entire intake assembly
5) Remove wire harness clip and heater hose clips so u can move them outta your way (passenger side)
6) Slide red clips back on Coil packs
7) Push black tab in and remove connectors
8) Remove all coil packs
9) Remove each plug
a. USE THE RUBBER HOSE TRICK DON’T USE RUBBER LINED SOCKET
b. USE SWIVEL SOCKET
c. HAVE A MAGNET HANDY just in case
d. USE VARIOUS EXTENSIONS (SOMETIME EASIER TO SLIDE EXTENSION ON THE PLUG THEN CONNECT THE RATCHET)
e. TAKE YOUR TIME SLOW AND STEADY WINS THIS RACE.
10) Replacement is opposite of removal
11) Clean your throttle body while its exposed.
12) Have a beer you just saved a few 100 bucks.
13) 3 hours round trip
Devin1349
great read how much did you pay for your spark plugs all together??
P
PRRAM
you dont wanna know....$200.00 qty (16)
:wtf2:
07MegaCabRam
Chandler, Arizona
6.7L CTD
When I did a buddies Hemi - I think he got the factor NGKs for $55.
You can use Champions, as long as you use a copper core plug. Don't use Plats, Idm.. etc..
The difference between NGK and Champion is like Energizer to Duracell..
P
PRRAM
Go to a dealer ask about the service announcement regarding RAM with IRIDIUM NGK plugs having Champion plugs installed in Engines that came from the factory with NGK. I don't like doing things twice....just me. If you want to chance it the Champion Part is 9055 I think.
P
PRRAM
The vehicle comes from the factory with IRIDIUM plugs. The ones from Moes are not Iridium.
Devin1349
I havent bought any yet but i was curious when i saw the price
P
PRRAM
"Have I noticed any difference"
Yes I have alot of cuts on my arms from removing and replacing the plugs near the firewall. :)
9) Remove each plug
Aluminium heads and steel plugs,i don't care what NGK says,i'm still using Anti-Seize on the plugs,lol
P
PRRAM
LOL I actually almost did use anti-seize but then I was like ah lets see what happens.
VB712
Maxi_built
Va Beach
So no change in the way it runs or anything?
P
PRRAM
I wouldn't expect any change I installed OEM IRIDIUM plugs with OEM IRIDIUM plugs. I wasn't experiencing any issues to begin with just maintenance.
I have 75 miles on the truck.
Devin1349
so how do i know what kind of spark plugs to buy before i go and get them replaced at a shop, do i just let them figure it out?
Joey93
