4.56 gear and trans
Izzyb47
Northern NJ
Mopar 4.7l
Anyone with experience getting gears done know if you had to change any programming for larger gears. Or if the shift schedule needs to be programmed differently. Or any insight into anything that might cause the gear change not to work
EWC88
Southern NJ
You would want to program the computer to know the gearing has changed. If you have a superchips or something like that you would be able to do that and change your shift points if need be.
SilverStreak88
Houston, Texas
5.7 Eco Gasser
Definitely flash it for the gears, your trans will thank you for the gear upgrade.
Joey93
