4th gen throttle body after almost 30,000 miles and no catch can
garner
Harker Heights, TX
Well decided to clean my throttle body today thinking it would be pretty bad since it hasn't been cleaned before and I have no catch can, but it really wasn't
Front(top)
Back(bottom)
Towels after wiping it down
So for those of all that are worried your TB will be pure black without a catch can, don't be. Although it's still a recommended mod by many
garner
garner
Harker Heights, TX
Manifold or the tube? Either way, no clue. Didn't check either of them cause I couldn't get the sensor out of the intake tube
MikeG
Livonia La.
In the pic of the back of the TB. Is that a shadow or was you gasket leaking ?
audio1der
Airdrie, Alberta
That's exactly how mine looked after 10,000km.
I suspect the bulk of the crap goes through, and does not stick to the TB.
I'm not the #1 fanboy of catch-cans, but if they hold prolong the life of my truck then its $130 well spent. Better safe than sorry...
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
The reason why yours wasn't too dirty is because you don't have a tuner. The guys running tuners are getting a lot more oil pumped through the PCV which is why theirs are so bad. I have installed many TB's here on truck with anywhere from 200 miles to 90k miles. The guys with tuners and no catch can always have a lot more buildup on the back of the blade.
chuck
Maryland
2013 True Blue Big Horn
Interesting, thanks for posting your findings garner. Good to know that most of the crap accumulates on the TB when you're running a tune. I'm thinking I'll probably still get a catch can though. Like audio1der said...better safe than sorry in my opinion.
PS...hemi450hp, I tried to shoot you a PM the other day but your inbox was full. Could you send me a PM and let me know when you've freed up some space?
Hemi450hp
Moe's Performance
Preferred Vendor
Conroe, TX
2014 Ram 1500
Sorry about that. Box is clear now.
junior81
Bell,Ca
2012 crew cab sport
Surprisingly I had no build up on my stock TB and I've have been running a tuner for more than 2months. Changed out my tb to the 85mm and it still was pretty clean. Still ordered the catch can though and threw it on, It's a must have mod and i feel a lot better knowing im extending the life of my engine....thanks Moe's.
LB3711
Trumbull, CT
3.6L V6
hmm interesting. Next time I get a chance to pull mine off I'll have to check. I have been running a tuner for a while.
chuck
Maryland
It's funny how some guys on RF pull their catch cans off and have a ton of crap in there, and then there are instances like these when the TB isn't too horribly dirty.
I guess it must take a little time for the crap to build up even when you're running a tune.
Hemi Joe
Berks County, PA
My throttle body was pristine after 10,000 miles. I still installed a catch can and after 100 miles it had a bunch of oil in it. Oil lowers your octane rating, so I'd rather catch it than burn it.
chuck
Maryland
Very good point.
garner
garner
Harker Heights, TX
I'm gonna go with shadow
Very true. I would definitely get one if I kept my truck long enough
What's the difference between tuned and untuned? Cause I know one post I believe you said the harder you drive, the more oil and I drive mine hard everyday so I figured it would have more build up on it
No problem. And I'm not denying the effectiveness of the catch can, I would get one too if I actually kept vehicles long enough till warranty ended, but just posting the results of mine without it
Yeah better to be safe than sorry
Yeah definitely interesting about the varying results
That's crazy. Guess it doesn't really stick to the TB, more so the intake system then maybe
garner
garner
Harker Heights, TX
Guys as a comparison, here's a post I made on another forum with my R/T
Front/top of the throttle body
Back/bottom of the throttle body after 15,000 miles
4th gen Hemi without engine cover
Air filter after 15,000 miles
Synolimit
Ohio
I can't see the tb getting that dirty anyways. The port coming from the pcv is under the tb. Air flows in past the tb then the port for pcv. Whether under vacuum idle or punching it, air rushing by that port shouldn't let oil back track out of the tb or on to it. A true sign of dirty should be the manifold, not the tb.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
They get very dirty over time as the oil is in the air as it is recirculated through the pcv and hose back into the TB. Yes the air flows through but the oil sticks to the TB and eventually restricts the flow some and can cause rough idle and less than ideal throttle response. Catch can is very functional and my guess is you would be surprised what they catch.
Plus the oil that is burned without a catch can is hard on the oxygen sensors and you will not get as good of burn trying to burn oil with gas and air.
$miley
Synolimit
Ohio
They get very dirty over time as the oil is in the air as it is recirculated through the pcv and hose back into the TB. Yes the air flows through but the oil sticks to the TB and eventually restricts the flow some and can cause rough ideal and less than idea throttle response. Catch can is very functional and my guess is you would be surprised what they catch.
$miley
Was this supposed to be a response to me? A lot of your info had nothing to do with what I said really. I have a AOS that I make so I know everything you said about a catch can. But as the OP said his was clean without one which is why I said judging the oil being let in based off the tb isn't a good idea. The manifold is a better one since again air doesn't flow backwards, it flows forwards. Unless you have some crazy turbulent air, the tb should remain somewhat clean like the OP's has for all those miles.
smiley
Minot, ND
2014 Ram 2500 Crew
6.7L Cummins
Yes, because you are saying it should not get that dirty but many have shown that it does.
I do have a theory though I am thinking it is worse for those living where it gets colder because there is more of a difference in temps there is more moisture and the when the moisture and the oil meet they make a goo that tends to stick more. This is just a theory as I know my TB was very dirty when I did the catch can at about 50k. I don't know all the science behind it but in my case it made a big difference and I am not sure why there is so much difference between one truck and another just seems to be conditions that may make a difference. It could also be trucks that are used more for towing as I do work my truck fairly often and maybe that is a factor I am really not sure but it does seem to matter having a catch can. No I do not sell them or have a vested interest in anyone buying one.
Synolimit
Ohio
Only difference I can think of is driving style like punching it more. Someone did say the more mods or power makes more oil on the TB which kinda makes sense about what I said about turbulent air. More rpms, the more air, the more pressure in the block, the more release of that pressure and the manifold sucking the blow by out, equals more oil on the TB.
I would advocate everyone get one though. My truck has 2600 miles, I installed it at about 600 maybe 1000 and I just pulled a good 4oz of oil out of my AOS.
Mohamed elgalal
