5.7 Hemi No-Mess Oil Filter Change
1stHEMI
BFE Idaho
After the first time I made a mess changing the oil filter, I decided to come up with a better plan. It worked, but that was the 'prototype' and this time I finally decided to make a video and share with others.
This is what I do, and it keeps me from having to wipe up a mess afterwards, so if it will work for you, I'm sharing it. If you have a better way, make a video and share it. I've used this for three oil changes and no mess. (except that time I kicked over the filter full of oil before installing it). lol
Do you make video's and narrate them for a living,lol.That's one of the most professional home video's i've ran across,and it's good.Great idea
kad
Hudson Valley, NY
5.7L HEMI
Very clever idea. I've never seen a flat sided water jug like that sold around here, but I'll be looking for one now.
-K
1stHEMI
BFE Idaho
Thanks...
I started dabbling in video production a couple of years ago for TV commercial at work; I've done some voiceover work in the past, so I have a little experience but far from professional. Getting better though.. I hope!
1stHEMI
BFE Idaho
That's a good idea!
However, contrary to the video, I use a filter wrench to tighten the filter 3/4 to 1 turn after the gasket touches the engine block.
I learned the hard way to not use a wrench to tighten, couldn't get a filter off one day. To each their own, but I get it hand tight and then give it one last twist - usually get an extra 1/4-turn from it, using a wrench is fine, but too many think they need to crank on it, and that's not really necessary. That rubber gasket (get it wet with oil so it goes on better) will expand a little with the heat and keep the filter tight.
indept
South Jersey
Great idea. One suggestion, attach a hose to your funnel ( use silicone caulk to make the round hose seal tightly around the square funnel). That way you can run the hose right into the pan or a jug and make it windproof.
1stHEMI
BFE Idaho
Good idea. I usually put the drain pan on something so it's higher up, but it gets in the way for shooting video. I have a small step stool/tool box that I use and it puts the pan right up there under the drain.
JHoward
NW, Louisiana
5.7 Liter
I have already been using this method for quite awhile ... I use an empty half gallon used Clorox bottle because the smaller diameter fits between things better ... I purchased a oil funnel/tube and attach the tube with the screw on shut off/on plastic valve to the old Clorox bottle ...
huntergreen
Engine filters are know to back off and leak once in awhile. I give an extra 1/2 turn on m ine. Goes against everything I was taught also.
RamHemi18
Brilliant! I will be doing this next oil change. I dumped a whole filter full of oil on my power steering rack last oil change. Pretty sure my neighbor heard me swearing!
turkeybird56
Central Texas
Same
Govtman
Oklahoma
Nice.
