- Joined
- Oct 7, 2023
- Posts
- 159
- Reaction score
- 198
- Location
- Bay Area, CA
- Ram Year
- 2022
- Engine
- 6.4 L Hemi
What I want to do (Why I am asking): Hard wire a Dash Cam into the overhead console with a hot (+) and the hardwire kit for both the Hot (+), Select / Accessory (+) and then earth ground (-) to the bolt in the roof of the cab.
Basically do the same thing as if I ran the camera's hardwire adaptor cable under the headliner, down the A Post and to the Fuse Box.
ASK: Can someone tell me if there is already a dedicated hot (+) wire that runs to the Upper Console, (RAM 2500) or confirm that there is not? To do this wiring at this console, I need an always hot (+).
I do not have any schematics for the wiring harness at the Overhead Console but already can guess that there is not a dedicated wire that bypasses the ignition to the Overhead Console (can't think of why there would be a need or why they would terminate a non-select power source there). Even the overhead lights go out after 10 minutes.
Note: I do have the self dimming mirror, so I know that I can order a Dongar Technologies Dimming Mirror Harness adaptor for the select / accessory on power if I just want to go that route. However, that does not cover me for "Park" mode on the camera.
What I plan on doing:
If no current hot wire exists to there, I'll just run the commercial Wire adaptor Kit with the battery low charge protector for the Camera to the fuse box.
