A couple more questions
deerhunter_24
Alright guys I got a update. I went ahead and purchased bilstein 5100's like I was advised to do. I also got motofab 1.5" rear coil spacer. I have 6" magnum raptor nerf bars ordered as well. Decided to keep factory rims as I am on a budget at the moment along with the same size tires which are 275/60r20. With that being said should I go with 2.1" on the bilstein and leave it at that or should I go ahead and go 2.8" on the bills and put the 1.5" rear coil spacer on? I did get cooper at/3 all terrain tires put on but I am concerned on how it would look with keeping the tires the same like I don't want a big gap in the front. Also which would get the truck more level? 2.1" bils without rear spacer? or go 2.8 with 1.5" rear coil spacer? Thanks
gassersarentdead
ohio
Which would allow 35s, but he's staying on stock ****. I'd go 2.1 until you can get better tires then go max and add the rear spacer.
Padilen
OP when you ask questions like this your getting opinions of others on the Internet. It's your truck you know your likes and dislikes. Look at pics ask for pics then decide what fits you.
gassersarentdead
ohio
I ran bilsteins at 2.8 for almost 4 years. I know how much they raise the front and what tires will look good and what will look small.
Padilen
Opinion it's what looks good to you. Just like I don't like the looks of big wheels with rubber belts. But you may.
Thatdude596
buckeyes state
2009 ram big horn
and the f250 super duty is the best looking truck out, right gasser lol
chipmaker
AZ
I'm at 2.1" on 35s... looks good, rides good.
JustinRam1500
