Auxito LED's everywhere review.
rjbar46
Oklahoma City, OK
2018 SLT Crew cab 4X4
After reading several other reviews on here I decided to put the Auxito's everywhere, turn signals, brake lights, reverse, third..etc.
My Truck: 2018 Quad Cab, 4X4, 6" bed, hemi, using the KADO tech bypass harness and AlphaOBD.
I got my lights from Ebay.
here is the store https://www.ebay.com/str/autoxlighting?_trksid=p2047675.m3561.l2563
Low beam: https://www.ebay.com/itm/334157155733?fits=Model:Ram+1500&hash=item4dcd518d95:g:beoAAOSwYFNhS1DJ
Hight beam: https://www.ebay.com/itm/334193819464?hash=item4dcf80ff48:g:41sAAOSwobxhdgmj
Turn signals:https://www.ebay.com/itm/334214363331
Brake: https://www.ebay.com/itm/333575461223
Backup/thrird brake/cargo lights: https://www.ebay.com/itm/333761228496
I have has these installed for a little over a week and finally drove at night last night and OMFG are these bright!!!!!!!!!!
The high beams have a resistor gbuiltinto the lead so I had no can bus errors, there others bulbs did not have a resistor and I did get light out warnings. I used AlphaOBD to switch everything to LED.
All of thee bulbs seemed well built, small, and of good quality, especially for the price, basically I got my entire truck in LED light fo just slightly more than one set of LED's from the "name brands".
On the brake lights, I went with the red LED because I read a few reviews that said white will wash out the red plastic lens, I do not for sure, I just figured that it was best to go with red.
On the turn signal bulbs, note that the running light part of them is white and the flasher/turn is yellow, I really like this since I installed the Oracle halo's now I can just use the parking lights as my DRL along with my halo's and its really cool when I use the turn signal as it is now a sequential signal.
I did make sure my headlight aim was no to high, I turned the aim down about two full turns, and so far I have not been flashed once.
High beam warning! Do NOT get/use these for the high beams, they are not adjustable/clockable and are not in the correct alignment for the quad headlights (https://www.ebay.com/itm/334238986187?hash=item4dd2322fcb:g:86oAAOSwIuxhp80-) I do not know if they will work for projectors.
Interior lights I used this kit - yea, not Auxito, but still was good. https://www.amazon.com/gp/product/B09JKPHPZ6/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
I tried to use the Auxito 921's for the interior lights and the bulbs are just to big, which is why I want with the kit off amazon, of note that kit put all interior light into LED and I had enough to install bulbs in the license plate lights and the actual third brake light and I have extra left over. I used the Auxito 910's for the cargo lights in the third light assembly.
Fog lights: My OEM fogs had cracked lenses, so I put these in: https://www.amazon.com/gp/product/B089CRNSH6/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
I have to say that they were amazingly easy to install. they fit right in the place of the OEM assembly. They look great and are bright as all get out! nice crisp cut off and not blinding oncoming traffic!
Video of the sequential signals.
https://youtu.be/jxC8jRr9fs4
I will update this thread if I have problems or more info.
rjbar46
rjbar46
Oklahoma City, OK
It is just how it happed to function after installing the Oracle Halo and the LED turn signal bulb. I did nothing special to create it.
Orca
