Our bumper pull did great behind the hemi, it was even 36' long as well... a fair bit lighter but i believe the wind resistance against the front cap of the 5th wheel is what killed the hemi's economy...
Yeah, a lot of people underestimate wind resistance. There is a HUGE difference between towing a 10k lb flatbed trailer versus pulling a 10k lb flat nosed enclosed or a 10k lb 5th wheel RV especially at speeds above 50 mph. Below 50 mpg, tire resistance is usually the main drag.
Wind resistance is a little worse for you now since you have a long bed, and the wider the gap is between the trailer and truck cab, the greater the turbulence. Although it probably isn't that much worse in comparison to the short bed you had before. People would be amazed on how much horsepower is needed to overcome wind resistance.
I don't know if I posted this here before, but it is a good read even if it mainly applies to big Heavy Duty trucks and trailer. These same principles apply with all vehicles although the rpms they are talking about would be a little higher on the 6.7L Cummins and a lot higher on the 6.4L or 5.7L. I should have posted this in the that 2015 Power Wagon towing report thread to show what I was talking about with wind resistance being a major factor especially in colder temperatures due to greater air density since every 10° F drop in temperature, aerodynamic drag increases by 2%.
Secrets of Better Fuel Economy
The Physics of MPG
By the way Avolnek, if you read in there where it talks about gearing recommendations and tells you to go to Cummins Powerspec, the Powerspec application will tell you that the Cummins 6.7L should be at 1,800-2,100 rpm for optimal fuel efficiency when towing. The 6th gear on our trucks is too tall to put us at that rpm which is why I always recommend to use 5th when towing since it puts you right about 1,900 rpm when towing at 65 mph and a little over 2,050 rpm when towing at 70 mph. If you are towing at 80 mph then 6th would put you at 1,800 rpm, but I don't recommend towing that fast.
Edit: For anyone towing a 5th wheel, I would also recommend aerodynamic aids. Some products, like the AeroShield wind deflector by Icon, really do make a difference in mileage and with general highway towing of these big brick behemoths.
