DRL Activated Projector Headlight LEDs
Farmer Fran
Farmer Fran
Earth
2020 Limited Loaded - Sold
really a 2015? Which letter is in your vin at 10th position?
I do not know when RAM changed this, but something seems to be a surprise :)
Since I do not know what year truck I bought... :crazy:
Position 10 - F = 2015
Position 11 - S = Warren Truck Assembly
Maybe it is because it is a Sport which has a different PCM/ECM
Straight from Ram
"ENGINE
NEXT GENERATION ENGINE CONTROLLER
The next generation engine controller is a powertrain controller consolidating both engine and automatic transmission controllers into one component. It provides better coordination between engine and transmission functions for excellent performance and efficiency."
Farmer Fran
Farmer Fran
Earth
firemedic10584
Central Fl
I'm not sure if I posted in this thread, but if you're unable to get your dealer to activate your LEDs as running lights on your truck, the DRL-1 module is 40$ and requires no cutting of stock wires to be installed. Just an option for those of you who are wanting them on with no success like I had. But now -
Ram48
Hemi 5,7
Thanks, yes a 2015. I have also a 2015 sport, but it is not possible to turn the DRL on with salescode. I think there are different versions.... (mine is built for canada)
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
PM me if you would like help with the module install.
Could you start a new thread and post the info, Pn's, links and how-to (possibly with pictures)?
I may be doing this at some point and it would be much easier to locate the info from a subscribed thread's op.
Up All Night Sleep All Day via my LG G4 on Tapatalk
Ram48
Hemi 5,7
schul788
I got the white/amber switchbacks and got the DRLs turned on today at the dealer. 2015 Sport. They knew exactly how to do it.
chrisc60
I finally got the local dealer and had the ambers activated. Code LM5. Did not take them long.
:favorites13:
So, do you know if on my 2012 ram this code will activate the ambers and deactivate the headlamp DRL's? I'm willing to try it- waiting for a dealer to call me back.- Chris
Sent from my 9020A using Tapatalk
Orca
