Engineering menu on 2018 Ram 1500 Uconnect...
TexNorseman
2018 Lonestar Edition with Black Out Package
How do I access it? I'd like to do a factory reset and see if it fixes my Bluetooth connectivity issues. I tried holding the volume and browse button, as well and the hot and cold buttons on the driver's side. Neither worked. Ty in advance.
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
Ugh. I have notes for this somewhere on the new Panasonic radios. Can't recall exactly but ...
Press: (Hot)+(Cold)
for 6-10 secs to get into the dealer menu. If you have dual zone use the driver's side temp buttons.
Then to do a reset ...
touch the VERY upper right hand corner of the screen for about 10 seconds..
let me know if that does it.
M² Mods - From my non Flammable S7!
TexNorseman
TexNorseman
I'd love if you could find it because all I am doing so far is adjusting my climate...LOL
Mpgrimm2
Preferred Vendor
SC
5.7L
Previous post updated
TexNorseman
TexNorseman
I'll try it again and see if anything happens
Mpgrimm2
Preferred Vendor
SC
5.7L
@TexNorseman
Did that work?
TexNorseman
TexNorseman
@TexNorseman
Did that work?
Pushing hot and cold (drivers side)with defrost brought up a "Dealer Menu" , I will now try to hold the right hand upper corner as you suggested. FYI I had to put the ignition in Accesory mode first for this to work. Would not do it in Run.
Sent from my VS995 using Tapatalk
TexNorseman
TexNorseman
No luck after getting into dealer menu, holding upper right hand corner does nothing.
DeereGuy
Preferred Vendor
Pittsburgh, PA
You have to stick you finger up almost under the bezel and push for what seems forever. I did hear from someone that they might have removed it. If they did that really stinks. It was the only way i could reliably get the radio to take settings from the BCM. Could you post a picture of the radio part info screen in the dealer menu? Is yours a nav unit?
TexNorseman
TexNorseman
Deere yes I can, I'll do it tomorrow. I placed my finger everywhere on the screen trying to find the "sweet spot". Nothing took. Wife was gone on a business trip for three days, so I'm spent some QT with her tonight! [emoji6] And yes it is a nav unit.
DeereGuy
Preferred Vendor
Pittsburgh, PA
Deere yes I can, I'll do it tomorrow. I placed my finger everywhere on the screen trying to find the "sweet spot". Nothing took. Wife was gone on a business trip for three days, so I'm spent some QT with here tonight! [emoji6] And yes it is a nav unit.
Hope you have better luck finding that “sweet spot” tonight lol
TexNorseman
TexNorseman
Yessir me too!
TexNorseman
TexNorseman
RASelkirk
Port Neches, TX
So far I've gotten into (2018 8.4 nav):
"Dealer Mode" using temp up, temp down, and defrost.
"Supplier Mode" using temp up, temp down, and press tuner knob.
But no sign of "Engineering Mode" yet. I'd love to see about turning off Travel Link, or at least the near-constant air quality alerts...
Russ
mpd2434
I pressed the hot and cold buttons at the same time, my first try adjusted the temp. settings the second time I must have actually pressed them at the same time because after roughly 5 to 6 seconds the engineering menu came up. Factory reset worked for my GPS problems, then just had to reset all my preset radio stations and sounds controls to my liking.
RASelkirk
Port Neches, TX
Doesn't work on an '18. Pressed together, hot & cold always runs the temp to max and does nothing else...
Russ
2018NightRam
LA
Don't want to hijack this thread but will any of those menus allow you to adjust the default volume for things like Bluetooth or navigation on a 2018?
LCACER
Just curious, have you tried the "Assist" option on the mirror?
RASelkirk
Port Neches, TX
You know, I need to go back and look again. Thought I'd seen something like that in one of the main menus but couldn't find it the other day after I noticed the Pandora (thru BT) volume is so low I had to turn it up full. Then the switch back to radio is killer!
Russ
2018NightRam
LA
Russ
Thanks! Let me know if you find it. It's driving me crazy
