Fuel Filler pipe question
Discussion in 'Tech Info' started by apochromat, Sep 11, 2016.
  1. apochromat
    apochromat Junior Member
    Sep 11, 2016
    Ram Year:
    1992
    Engine:
    5.9 Cummins
    Howdy - look forward to visiting here often. My project is a 1992 D250, with the 5.9 Cummins. It is sound in the drive train, but needs a lot of details fixed. It originally had a utility body on it, but then at some point received a new bed. The existing fuel filler pipe is too short to reach the fuel door.
    I ordered a new Spectra filler pipe, but either I'm missing a piece that connects the pipe to the body panel, or I have the wrong filler pipe. I'm suspicious that maybe the bed is a later model, that takes a different filler pipe.
    [​IMG]
    suggestions would be appreciated
  2. crazzywolfie
    crazzywolfie Senior Member
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    your missing the plastic piece that bolts to both the bed and filler neck.
  3. apochromat
    Sep 11, 2016
    Ram Year:
    1992
    Engine:
    5.9 Cummins
    Thanks - any idea what it is call in the part lists? I've found references to "fuel filler protector" But after a day of searching I've come up empty.
  4. crazzywolfie
    14,039
    2,138
    Apr 6, 2013
    under the truck
    Ram Year:
    81 93
    Engine:
    5.2
    i don't know what it is called. i think you will have to find one used but it should not be too hard. they are used on every 81-93 ram truck or ramcharger. even if the box or body is rotted out that part should still be in good shape.
  5. apochromat
    Sep 11, 2016
    Ram Year:
    1992
    Engine:
    5.9 Cummins
    Ah ha! success!
    Knocking around Ebay, I found a "filler pipe protector" for a Dodge Dakota. It looks like it will fit, give it a try in the next couple days
  6. apochromat
    Sep 11, 2016
    Ram Year:
    1992
    Engine:
    5.9 Cummins
    Success!
    The fuel filler pocket for a Dakota works, and so it's all installed successfully, now. Thanks for the suggestions!
Share This Page
