Narg
- Oct 12, 2019
- 390
- 330
- Location
- Tulsa, OK
- 2020
- 5.7 eTorque
The government has only safety interest in truck capabilities, but doesn't mandate much. Lawyers, on the other hand, do have a LOT of interest. So manufacturers are forced by court cases to be very up front about GVRW and weights. They don't want to be part of any lawsuit in an accident if you overload your truck, and they state the wrong figures.
I'm like you, also put off by RAMs numbers. From their web site, the Longhorn I have should have 1,600 lbs payload. The door label on mine says 998 lbs. 600 lbs difference! Sure, I added a few things to the truck when I had it built, but I'd expect to loose a couple hundred lbs, not 600. Not too happy about that. If a truck can tow 9,000 lbs, it should be able to handle all it's seats worth of people AND 15% of the trailer (basically what tongue weight should be normally.) So, load the truck up with 4 200 lbs nice guys, plus 1,500 real trailer tongue (not unloaded tongue weight), 2,200 lbs (even more with gear etc.) No 1/2 ton is near doing that in reality (technically maybe, but legally no...) Some on raw stat numbers show they might be able to but I bet their door labels state very differently. The real tow rating for trucks should be much more realistic, or they need to beef up the axels and suspension to match their overstated tow numbers to handle the expected payload.
I kind of wish RAM would do the same as Ford and Chevy and make their 3/4 and 1 ton identical in features more closely. RAMs 1/2 tons are still very different from their 3/4 and 1 ton. That'd make changing up to a 3/4 or higher much easier.
