Headlight wiring... Tech help
Jalsaeed
This is my install on my 2012 ram, just need to add an LED load equalizer to get rid of the turn signal hyper flash.
T
Texasez
Dallas tx
Looks good. Those amber led are bright. Looks like you found the liquid electrical tape at lowes too. I've had mine on for a while with no problems. Plugs seem to be holding up well.
mxracer72584
Midland, MI
6.7 Diesel
hello, i am new to the forum as i just purchased my first ram, 2012 Express. working on doing the sport headlamp swap, purchased the harness from retro with load resistors. i have read the 2012's have a problem with humming on high beams. i have installed a relay and am testing to make sure it works properly, and although it does stop the headlamp humming, the relay is buzzing really loud instead? any thoughts on what my problem is? i have batt+ to #30, #87 to the high beam power, pin 7? #85 to ground, and #86 being triggered by the high beam driver which is white with light green stripe, blue on the adapter harness. but pin #1 is not going to anything anymore from the headlamp(yellow wire on adapter harness) help please!! thanks in advance!
mxracer72584
Midland, MI
6.7 Diesel
problem solved with some time experimenting, NO relay needed, just had to cut the yellow wire(relay driver) from the high beam wire!(blue wire) this was on the adapter harness from retro lights! they were spliced together!
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
well..........
Thats one way! ;)
Most trucks though, they want to keep the solenoids in the projectors working. You've disabled that now. Another way to do that? Pull the dust cap and unplug the solenoid. ;)
iNtErNeT_rYaN
HEMI 5.7
Clips took a hair extra trimming .
Ground on body panels and mounted this to metal there.
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
oh so spiffy
