Hemi Significant oil leak, pooling in valley
mrpineapple
Recently rebuilt engine (<1000 miles) and ever since then theres been a significant oil leak. I changed the valve cover gaskets again although it doesnt appear to be coming from them. Today I decided to wipe it all clean and run it while I lay underneath to watch for signs of oil. A couple minutes in (before the thermostat opened) I noticed a steady stream of oil coming down the passenger side all the way from atop the engine. I decided to take the intake off since that's where it appears to be coming from and noticed the valley to be filled with oil. It doesn't appear to be coming from the intake gaskets or the oil gasket on the intake, those are all new. I'm wondering if I'm missing something in the two threaded holes in the valley? See attached pictures, and any suggestions appreciated. Thank you!
Photo Album of Oil Leak
RonJon '06
Southern Minnesota
I would check the four plugs where the MDS solenoids would go. They should have O-rings, maybe they're cracked or missing? I'm not sure what those two holes are for, I don't remember anything going in them.
charonblk07
Calgary, Ab
F1-A forged 349ci
How much oil is inside the intake manifold? Since you have the intake manifold off right now I'd check the MDS plugs and make sure they're still in good shape, but I'd also check the PCV as well, if it's blocked or stuck open then it'll be pulling in oil in high vacuum which can account for large amount of oil being pulled into the manifold.
