- Jul 26, 2021
- 697
- 1,743
- Location
- NW, Louisiana
- 2017
- 5.7 Liter
just read a big dispute over this in another forum. Some guys believe this to be true, while others strongly disagree. (that lifters are not being oiled when mds is off) Some have said they turned theirs off from the start of owning their trucks and never had a problem. I haven't read anyone having lifter issues because mds was turned off. So, it seems its a theory right now.
I know there's a video on YT and the guy claims the lifters went bad because mds was turned off, but it was his theory, since hemis are/were notorious for lifter issues anyway.
So, if anyone here can honestly make a claim they had lifter issues went bad because mds was turned off, they should post it. I find it had to believe that the hemi was designed NOT to sufficiently oil lifters, because even when towing a heavy load, the mds isn't working...and that's a time when you want your engine oil flowing.
MDS was created to make a large engine, like a hemi, allegedly be more fuel efficient. I stated in a post that i turned mine off today for a 50 mile ride and i actually got better fuel economy and a more responsive truck, but, if you bought a truck with a hemi, fuel economy should not really be a major concern. As i was once told: "A hemi will pass anything on the highway, except for the next gas station"
My understanding about the lifter/cam issue was due to poor oil flow due to the VVT having the cam raised higher in the block and lower set idle rpm.
HEMI engines from 2009 and later with either MDS and non-MDS have had lifter/cam failures.
So, I'm not convinced that selecting 8th gear manually/tow haul mode overriding the MDS function will make any difference.
