How to wire up your HID harness
Trupiano
Registered User
6.7L CTD
Here's a great little guide on the harness install, just in case anyone ever needs it.
Here is how to hook up your wiring harness
Here is what get hooked up to what:
1. Connect to Left Ballast input
2. Connect to Right Ballast input
NOTE: 1 & 2 may be reversed depending on where your battery is and how long the
connector cable legs are.
3. Connect to the Positive + side of your battery.
4. Connect to the Negative - side of your battery.
Note: the negative power leg may also be connected to a solid chassis ground.
5. Connect to your car's stock headlight power cable.
Note: This connection can be to either the right or left headlight power connector.
The other headlight connector is no longer used and should be covered in electrical tape or other material to protect the connector ends from the environment.
How it works:
The Headlight power connector (5) powers the relay (6) which provides power
directly from the battery (3 & 4) through a fuse (7) to the HID ballasts (1 & 2).
Got it?
Aim your lights to somewhat look like this:
bigtigga84
dela....where?
Almost said no.... but I just go up. Looked at the picture better, and yes, makes more sense...... I think. Yep it does, good write up man!
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
:D
HIDs are fun.
sullivan
Houston, Texas
I don't know about on the 4th gens, but on a 3rd gen you need a resistor on the relay to make it function properly.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
yeah, this shows the basics of what goes where - the 4th gens need a cap on the driver's side to work.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
SWEET!
Day pics now please. :D:D:D:D:D:D:D
edit........gotta add this in - going with the "right" HIDs make a world of difference. I know you can get hids for $30 on eBay. BUT, they suck. Thats all. :D
sullivan
Houston, Texas
SWEET!
To be more specific, if you buy the right HID kit, you don't need a harness. There are specially made HID ballast just for the dodge ram. They are plug and play and require no resistors, capacitors, or harness's.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
I am still a little leary about the amount of power they pull on start though.......
SMITHY
KANSAS CITY
2011 Dodge Ram Quad 4x4
4.7 Magnum
What is the name of that kit, or do you have a link for it?
blackout11
alpharetts GA
2011 R/T
Now if we could get the tps to not come on for a few secs we be good to go lol ill take a few secs any day over flickering and not working.
EJM05
Somers, CT
440 Big Block
mine doesnt even turn on anymore when i turn the lights on.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
I can't remember if mine does or not!
quietpeen
2021 TRX
Hellcat
what do you mean by this?
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
HID ballasts create EMI, which can interfere with the TPS sensors, typically only at startup.
[yt]EeUUYOfbYH0[/yt]
JustinRam1500
