Ramzaq
- Oct 27, 2013
- 443
- 114
- Location
- Northern California
- 2009 CC 4X4 3.55 Big Horn
- Hemi 5.7
Got the XAC Flashed @ the dealer today took less than 15 mins from the time I walked in the door and drove away !
I was stoked about having the back up camera , I didn't notice I had no lines , I believe the lines derive from the purple wire spliced into the Orange / Dark BLUE wire from cavity 45 in C5 on the BCM ?
@ Mpgrimm2 thanks for your help sir with the post ! I actually did reference your post 90 &26 BIG HELP ! I posted the radio plug thing only to mention it again in the thread so people would be less likely to have an issue there .
I believe it was a post of yours as well on the back up lines being derived from the BCM spliced in wire . A question for you sir : do all the the radios have the lines ? I have the RA2 , I did splice the orange / dark Blue wire @ cavity 45 on the BCMs C5 connector with the purple wire from the OEM Kit harness . If all the radios have the lines feature, the I need to revisit my spice and maybe verify the body harness plug I populated ...
Pretty sure the warning lines are generated by the camera and not a wire hook up. At least prior to 2013 they were, some people installed kits with safety lines some didn't, older kits, all the same wire hookups.
