Jeff Krawczyk
well installed the 2.5 fox coilovers in the front and the 2.0 res in the rear I have to adjust the front up 1 inch and was going to do it today got the truck in the air and go to adjust it loosened up the bolt that keeps the ring tight and still can't seem to move the adjuster ring at all....do you have to uninstall these and compress the spring to take all the load off to adjust?. Seems that for the money these cost you should be able to adjust them while on the truck, **** how do you know how much adjustment it needs till after installation....anybody have these and adjusted them while on the truck...
