Lights galore on the dash
Discussion in 'Tech Info' started by WiSH2oo0, Dec 15, 2016.
  1. WiSH2oo0
    WiSH2oo0 Senior Member
    43
    313
    79
    May 15, 2016
    MN
    Ram Year:
    2017 1500 Express 4wd RCSB
    Engine:
    Hello all,
    Well two weeks ago my 2012 Ram 1500 ST 5.7l had a few lights come on in the dash. I pulled over and restarted the truck, all the lights went out. I thought all was fine until the same lights came on three more time since then.
    When it happened again today I took a couple of pictures to share. Illuminated lights are as follows:
    Trailer controller - CF
    Traction control light
    Service 4WD
    No trailer symbol
    All rear brake lights are on like I'm holding the brake pedal down
    Service trailer soon
    I ran the built-in engine code reader and no codes came up. When this happens I cannot use cruise control and the brake lights stay on while driving like I'm applying the brake pedal. I can see the third eye brake light on in the back of the truck. Any help would be appreciated.
    Thanks
    Moses
  2. whetrick1
    whetrick1 Senior Member
    57
    1,078
    215
    May 21, 2016
    Ram Year:
    Engine:
    My friend had this problem and found out it was a antilock brake sensor was causing the problem. Had it replaced and all is good now
  3. Tach_tech
    Tach_tech Senior Member
    31
    899
    431
    Jun 1, 2014
    Ram Year:
    Engine:
    5.7L HEMI
    You need to get an actual scan tool on there that can read communication and ABS codes. Even the built in key dance one only shows powertrain codes.
    MADDOG and Mpgrimm2 like this.
  4. ExpressRules
    ExpressRules Senior Member
    1,532
    741
    Apr 4, 2014
    Southern New Jersey
    Ram Year:
    2014 Express Crew Cab
    Engine:
    Well, it is Christmas time. :naughty:
    WiSH2oo0 likes this.
  5. MADDOG
    MADDOG Super Moderator Staff Member
    7,415
    1,967
    Dec 26, 2011
    Oregon
    Ram Year:
    Engine:
    Cummins 6.7L Turbo Diesel
    This!
  6. ramcares
    ramcares Senior Member
    960
    440
    Jan 21, 2016
    Ram Year:
    n/a
    Engine:
    n/a
    Hi WiSH2oo0,
    Sorry to hear about this! If you decide to visit your local dealership I'd be happy to follow up with them for you. Just PM our page and let me know.
    Andrea
    Ram Social Care Specialist
  7. WiSH2oo0
    43
    313
    79
    May 15, 2016
    MN
    Ram Year:
    Engine:
    I went into the local auto parts store and used the code reader. I also noticed in the sticky that it skips P0572. Here is what came up:
  8. Abdulrahman-Qatar
    Abdulrahman-Qatar Member
    42
    Jan 15, 2015
    Qatar
    Ram Year:
    2012 RAM 1500 LARAMIE
    Engine:
    I had this problem for many years, tried everything like speed sensors, connectors and so. Its horrible cz I could not engage 4wd as a desert driver. Finally I unpluged the 4wd actuator connector and cleaned it, now its fine. Its behind passenger side brake, disconnect it, blow with air and electrical degreaser and try. If it won't work it will not harm or cost you anything. Tell us if it works. Chears
    Firefighter14 likes this.
  9. Tach_tech
    31
    899
    431
    Jun 1, 2014
    Ram Year:
    Engine:
    5.7L HEMI
    Looks like there's a good chance you need a brake switch.
  10. Sir John
    Sir John Senior Member
    1,820
    856
    May 28, 2014
    Buffalo, NY
    Ram Year:
    2016 1500 Rebel "Mopar 16" Special Edition
    Engine:
    You beat me too it. I had very similar codes on my 14 Sport and it was the brake switch on the brake pedal.
Share This Page
