MDS issue
Podcast
Da sticks
Hey y'all. I've noticed an issue and I am unaware of how long it's been going on. My '13 Hemi rarely goes into Eco mode anymore. I do have about 90k on it but the only way it goes in is by letting off the gas pedal a lot and even then it doesn't hold. Ideas?
Sent from my LGUS997 using Tapatalk
DILLIGAF
Canada
Eco mode is just a light that shows you you're driving economically.
Podcast
Podcast
Da sticks
Eco mode light NEVER illuminates. That is not normal. Also, on the 13's it was directly related to MDS being initiated. Years before that it did not indicate that but the latter years it does. It is very easy to tell when MDS activates and it no longer does unless under extreme conditions. It used to activate going 55mph until I pressed the gas pedal and the instant mileage went below 18mpg. Now it doesn't stay on unless I'm getting over 30 and when it falls below that instant mileage the MDS turns off immediately and the ECO light is never on.
All of that is not normal. I also have a 17 and that is working properly in compliance to what my 13 used to do and what is stated above.
Get a tuner and turn that garbage off anyway. Eco mode if for soccer moms.
Podcast
Podcast
Da sticks
Unless your truck is your daily commuter of 80 miles round trip.
Try using tow haul for a tank and not tow haul for a tank and see what you get, my guess you wont be saving much gas unless you have a lead foot on the freeway.
charonblk07
Calgary, Ab
F1-A forged 349ci
Start by resetting your adaptives by disconnecting the battery for 20 min then hold the positive and ground cable ends together, this will clear the adaptive learning program and you'll fire it up with default program. If it still doesn't activate after that then you'll need to get a computer on it to see if the solenoids are activating during driving.
Podcast
Podcast
Da sticks
Thank you. I'll give it a shot.
Podcast
Podcast
Da sticks
Hey y'all. I'm gonna revisit this. I spoke with the dealership. I was informed that there is a PCM update that is currently out there causing this issue and the main complaint is 2-3 mpg less than what these trucks used to get. If you're experiencing this issue call, write, or email Ram and tell them. It's the only way they will correct this update is if enough people complain. I'm down right pissed since I drive a hundred miles per day.
