Modified Radio Bezel Question
adubree86
Indianapolis, IN
2017 Ram 2500
So I've gotten my radio bezel cut to size and bondoed. I will be painting it tonight. Does anybody have any tips or tricks for removing the AC vents or am I going to be stuck just masking everything?
[/URL][/IMG]
spankis
Cummins 6.7
I may also be interested in this. My bezel is black and I'd like it to pop a little more, and when I replace my head unit would be a good time to do it.
gunner1374
In the 405!!!
HEMI 5.7
Trying to remember because it has been a while, but A/C vents were easily removed. If I remember, I had to get a flat screwdriver and gently pry out while pushing up? You will just have to look, but there are tabs that help hold it in and you will need to kind of pull away from them to help come out. It sounds risky, but is very easy. Tabs on bottom half on vent on the sides I believe. Simple! You will see. Good luck!
adubree86
adubree86
Indianapolis, IN
2017 Ram 2500
It appears that mine are plastic welded. Not sure but will have to take a closer look.
Ftank
