crazzywolfie
- Apr 6, 2013
- 16,431
- 3,192
- Location
- under the truck
- 81 93
- 5.2
at least it sounds like it is working properly.
The only rust areas are the one on the top of the fender and the one on the bottom. Sanded all the others out already.Make sure you blast out that palm sander real good with compressed air every once in a while. All the **** you sand off builds up in it. You'll prolong it's life considerably.
Also, don't just go priming those rust spots, unless you want them to continue to grow.
Take care of em. Get rid of the surface rust, treat the metal and seal it properly.
only 6 bolts holding it on. since you live where rust is not such an issue you should have no issue taking it off.
bumpers are the same except yours is in better shape. mine had 1 ding in it when i got it and i just put another dent in it not that long ago.
