- Feb 17, 2020
- 738
- 2,304
- Location
- Orange County New York
- 2012
- 5.7
To reiterate about Mag/Moss in essence if you have aftermarket part that caused failure to an OEM part then the dealer doesn’t have to fix it by law. If you do get a 6” inch lift I can assure you will see premature/failure on drivetrain. A 6” lift is nice but in comes with a lot of other things you need to address. I would imagine for arguments sake with the lift you’ll add bigger tires maybe after market wheels and that adds to rolling resistance. Bigger tires are heavier, and cause premature brake wear, transmission and diffs all now change. Wheel bearings, axle shafts, and steering will also need to be payed close attention to. The gearing ratio will change along with the speedometer’s reading and actual vehicle speed you’ll be going faster. In closing if you want to lift it, then lift it. But be aware of the possible issue’s in doing so, if you do it right and stay on top of it then you should see years of trouble free ownership. You could always look to Rocky Ridge for some info as they do factory backed lifts.
