Need advice!!
Lownismo
So I plan on using 3 inch lowering springs on the front end when I lower my truck. I used 3 inch springs on my f150 and my s10 without any issues. Is the anything I should know or issues I need to know of.
Bullitt5339
St Pauls, NC
Shocks, shocks, shocks.......
Stockers are too long for a 3" drop. You will likely have trouble with alignment. That can be addressed by elongating the stock camber adjustment holes. Take the factory bumpstop out and cut the bucket out. It will sit on the bumpstops at 3". Order a set of Street Performance Shocks for 2" drop and a set of low profile bumpstops. Under the old buckets, there's a hole that's perfect for putting the stud of the bumpstop through.
Hold on to the steering wheel tight, you're likely to get some pretty good bumpsteer.
Goodie1990
