Need help asap!
97RamSB
Well 2 days ago my driver side A- arm broke. Came right off the frame while I was heading home.
Looks like they don't sell any replacement parts as it was part of the frame itself.
What do I do to fix this? Had a friend say he could weld it back on but it'll pull to the right all the time. (did it to one of his old hunting trucks) but the only problem he said besides it always wanting to yank to the right was it eats and I mean eats the driver side inside tire.
Any help is greatly appreciated as this is my daily
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
I would go and speak to a "high end" Bodyshop that has a frame machine. They would probably be able to weld it back on then tweak it with the machine to get it almost perfect.
mumbles84
5.9 magnum
you can weld it on but lyou should set toe before welding then after have an allingment done how to set toe measure tire to tire. you might have to remove tie rod ends from them being damage
Orca
