Need some help
lukezelina23
US
1986 ramcharger
I dont have any heat in my ramcharger is there a relay for the blower motor
Sent from my SM-G950U using Tapatalk
crazzywolfie
under the truck
is the fan not running? have you tried testing it to make sure it works? also does the ramcharger have a/c?
L
lukezelina23
US
1986 ramcharger
Fan runs good ac is disconnected
crazzywolfie
under the truck
so fan runs good but just no heat coming out? if so might be a clogged heater core if that is the case
L
lukezelina23
US
1986 ramcharger
I have no air moving when I turn the defrost on
crazzywolfie
under the truck
there is a chance the heater control might be going bad since i am guessing it is working in most of the other settings. if that is the case you may need to bypass the heater control with a switch or jumper wire. i had to do it on my 93
reek
Sacramento
2015 RAM 2500 CC 4x4, 72 D100, 73 D100, 01 RAM 2500 field truck
if the fan is running but no air is coming out of the top of the dash, is it possible your ducts have come dislodged/disconnected? the connections in the HVAC tubing system is pretty marginal at best.
L
lukezelina23
US
1986 ramcharger
Blower motor doesn't even try to kick on I'm think the dash kit is bad
crazzywolfie
under the truck
it is possible. just to make sure you checked the fuse right? there is a blower motor resister but it should usually at least work with some of the settings even if it is the max a/c setting
L
lukezelina23
US
1986 ramcharger
All the fuses are good first thing I checked
OasisNinjaBat
