If reliability was an issue with the hydroboost system do you really think it would be the system used in the HD trucks, including the 6.4L gas engine which pull a hell of a lot more weight and use the truck's brakes to slow and stop? I guess they just used the hydrobooster in the 6.4L because it performs better but is less reliable than a vacuum booster. Your fear mongering is pointless, the system is reliable and PROVEN. The system is installed the exact same way as it is on the 6.4L HD and diesel trucks so please just shut up about reliability because these trucks drive around all the time WITHOUT crashing because of hydrobooster failure.
Seriously, what if you have a belt failure or the engine stops? Having thrown a few belts with this setup because one idler pulley being too narrow (since changed out) AND having had to kill the engine while driving due to the lovely lightening bolt I can tell you that you still have brakes; there's plenty of pressure in the system even after the pump stops spinning to allow you to safely brake and pull over to the side of the road. Please relate your experience with this setup in either of these two failures that you've mentioned.
You don't like the system, fine, I don't like asparagus, which is why I don't eat it but I don't tell people they shouldn't eat it because I don't like it. In this particular case you are confusing opinion and fact.
Slow down there dude.
They use that system because it makes it easier to apply a large amount of force without having to have a massive brake booster. It comes down to packaging sizes.
My point was that a hydroboost system has more points where it can fail, and includes all the points of failure that a vac boost system does with the exception of the vac system. You can argue all you want that the HD trucks do it reliably, but that's an OEM truck designed for it, ours are not.
And sure, you can make a single stop getting to the side of the road when you snap a belt. You could do the same with a vac boost system. But if you snap a belt on a vac boost, you can actually still drive around for a little bit before your engine will overheat or your battery will die and have brakes. No such luck on the hydroboost.
Lastly, I think you should stop having such a condescending attitude. I get that the product works for you, but it's NOT the best decision for everyone, and some of us on here have quite a bit of knowledge about these things, not just you. I completely agree with the reasons you have it and why Matt has it, but in the end it will not improve braking performance like a properly set up system of calipers, rotors, and pads would, period. All it does is reduce the amount of petal effort to produce a given clamp force from the calipers. It won't prevent your brakes from getting overheated. It won't increase the brake torque unless you already have an issue with not being able to produce enough clamping force, like Charon did because his vac pressure is low.
