R/T_Fire
- Feb 3, 2015
- 3,432
- 1,205
- Location
- Pleasant Grove
- 2011
- Hemi 5.7
The 3rd gen spindles are the same as the 4th gen spindles BUT the SRT10 spindles are different altogether, there is no crossover between the two since even the lower balljoint location is slightly different due to a different caster angle. The spindles can be bolted to the control arms then the calipers will bolt to the spindles but you will also need new hubs. Unless you have a wrecked donor truck you will be shelling out the same amount of money buying new parts to do the swap as you would have spent on the SSBC kit.
This topic comes up every time brake upgrades are discussed and the reason you can only find 2 examples of people actually doing this swap is because it's cost prohibitive without a donor truck. I just priced out the new parts required on Rockauto and it came to $1200 so it would a bit of a cost savings but not much considering a set of SSBCs on AutoAnything start at $1200
Are the SSBC 14" or 15" rotors? I thought the Baer was the only 15" set up on the market, that's why I compared to that kit not the SSBC. IF the SSBC are also 15" then there is no point and I will go back to my previous statement of its more work than its worth, especially if a 15" kit can be had through SSBC for 1200-1900 which is the pricing I've seen for the kits
