conrad_vanl
First time ram owner 2015 1500. 60k miles. I don't commute and needed a truck for side projects/occasional usage. I put maybe 3k miles on it a year.
Brought it home from the dealer and noticed the instrument cluster lights won't turn off when the vehicle is off. They just stay on. There's a couple of other posts around here on this forum and others, appears all FCA vehicles can have this problem, but I'm not clear on any singular cause of this issue. The dealer is going to look at it this weekend as they'll have a certified FCA master tech in (they're a non-dodge dealer, but really top rated and have been great to work with). First time I've bought a used vehicle without either factory warranty remaining, or CPO. Has been nerve wrecking.
Anyways, I noticed something else strange. The low-beam headlights won't come on manually. We've been driving around with headlight switch in auto. When I checked car out at dealer, we had it pulled into a garage when I checked the lights and it was just on auto. I was looking at it in my driveway in the daytime and so I switched the headlights to manual on...and nothing. High beams work, fog lights work, emergency / blinkers work. But not manual low beam.
Is that a sign of a bad BCM? Or is there potential that there's a wiring fault on the headlight switch, which is also causing the instrument light issue? FWIW, the vehicle "acts" like the headlights are on when I switch it to on....the headlight light illuminates and the cluster dims. Just no headlights. Switch it back to auto at night, and headlights are on no problem.
Thoughts?
Thoughts?
