OEM 4 Button AUX Switch Panel
dogcar3
2012 Power Wagon
Is there a way to use all 7 spaces?
The panel uses a printed circuit board behind it. Not sure if it can be done or not, but adding more factory switches to it would require a great deal of soldering work. You may be able to find a place to drill through the board to run wires to an aftermarket type switch mounted in the blank locations.
fasthemiram12
Eagle 5.7 vvt
I think I just found my nitrous switch, my water pump switch, and my line loc switch.
Cruizer
Ohio
2010 Sport 4x4 QC
So is there anyway to add switches like these to the existing panel? I have to empties on mine and would rather use those the drop another one in just for 2 switches.
LETHAL GTS
Winnipeg MB
Ditto....that's what I'm looking for as well.
kkreit01
Olathe, KS
Very nice. Ram should have left the 3 center dummy switches solid, and had a small RAM logo here.
LB3711
Trumbull, CT
3.6L V6
Power outlet in my center console. Just to power the switch.
Sent from my Nexus 7 using Tapatalk
DeputyDipShizz
Pennsylvania
Anything like this available for the 2008 where the power rear window resides? Would come in quite handy and clean looking for my emergency lighting install...
Sent from my EVO using Tapatalk
LB3711
Trumbull, CT
3.6L V6
did they have that option for the 2500/3500? thats where our switches came from
DeputyDipShizz
Pennsylvania
You guys are the know it alls...I'm outta the loop haha
DeputyDipShizz
Pennsylvania
Can anyone give me measurements on this panel by chance? Measuring the full width front and back of the unit as well as depth would be awesome!!!
LB3711
Trumbull, CT
3.6L V6
mine is already in. I cant help ya
LB3711
Trumbull, CT
3.6L V6
I have the blank in the house somewhere. I'll have to measure it tomorrow.
murraygc
Not sure exactly which measurements you are looking for.
First time poster here. Will try and answer. I'm currently using the information in this thread to put in my own functions on the auxiliary switches, so I just got mine.
The switches themselves sit on a base that sits in a little frame that replaces the frame on the Dodge RAM insert for the centre console, so if you have the Dodge Ram for the appropriate years, you have the console, and you likely have the RAM insert, and therefore have the approximate frame measurements.
The switches are mounted so they are in a similar arc to the centre console. I'm not sure of best way to measure that arc, but again, if you have the console, you have the arc.
The base of each of the 7 switch blocks (4 working, 3 blanks) is rectangular, about .95in by .8in.
The base the switches are set in is about 6.75 in by 1 inch.
That base is in the frame. It's so irregular, I'm not sure how to measure it.
Does that help?
I can't figure out how to upload more than one photo. Urggh.
steady_yeti
4.7 liter V8
Does this switch panel work in 2013 models? Everyone here seems to have 2011/12.
murraygc
Not sure, sorry. I have a 2012.
myoung84
myoung84
Tulsa, OK
2012 Power Wagon
No, this will not work on 2013s. The dash has changed.
Joey93
