performance gone need some help
96REDSLED
5.2 MAGNUM
I have a 96 with a 5" running 35x12.50R20. Front has a Dana 44 and the rear has a Chrysler 9.25. Both axles have the stock 3.53 gears. I am pondering 4.56 gears but I am wondering if I am losing power through the trans. The truck struggles to do 60 Mph and when I get there I loose all vacuum operated systems. Should I go ahead with the gears or get the transmission looked at?
I recently added short tube headers, cut the cat, cold air intake, and throttle body spacer. Stage 1 chip as well.
Merc225hp
NA
truck
gas
Re gear to 4.56 or 4.10. As for the vents do a search for wild vents here on rf.
As for the tb spacer take it out and toss it away. Please explain stage one chip.
jsmith
Have you fixed your plenum yet?
Is the "chip" one of the ebay specials? And yea the spacer will give you just as much a performance increase sitting on your desk as a paperweight.
96REDSLED
5.2 MAGNUM
Jet brand stage 1 pcm chip
96REDSLED
5.2 MAGNUM
Haven't heard of the plenum problem. Elaborate olease.
96REDSLED
5.2 MAGNUM
The chip is stage one jet performance pcm chip. What plenum problem are you referencing?
Johnn123
Ontario
This. Also look up the plenum fix.
Chips are wastes of cash, you need an actual tuner. TB Spacers, also a good waste of cash. Good paper weight though.
Merc225hp
NA
truck
gas
Stage one chip is junk sorry to say the, pcm just over rides it.
MagSport
South Carolina
Good tuners are sct with either hemifever or flyin Ryan tunes or superchips. Hypertech tuners, jet chips, and any kind of ebay chip won't work.
Joey93
