Please help!!! Dodge
JDavus
5.2 magnum v8
I have a 1996 dodge ram 1500 v8 5.2 with 318. Had a complete tune up done n intake gasket replaced. What's cause in lack of power with some what spit n sputtering. I been told the head needs rebuilt or new. Any other suggestions before I go spendin more than I need to.
J
JDavus
5.2 magnum v8
Has no cats could that be the problem? Or could I just doin a engine rebuilt kit on it n fix it?
nim81
Fredericktown, MO
5.7L
any lights on,
ive had this problem on a 318 in a Durango,
turned out the be the round doughnut sensor under the dist. cap. forgot the name of it its been forever ago. maybe crank sensor but with different name
J
JDavus
5.2 magnum v8
It won't get up n go ill give it gas n it'll go some n then it'll act like I ain't pressing the gas pedal
leadrofthepak
Shelton, CT
Check the fuel pressure at the rails. If you have plenty of fuel pressure, check spark. I am not sure why, but many people forget to replace the coil when doing a tune up and they fail just as hard as plugs, wires, cap and rotor... could be the coil if this is the case. Who did your tune up? You 100% they did it correctly, firing order, wire routing, etc.?
How many mile are on it? Have you ever replaced the fuel pump?
Hope this helps ya narrow the problem down a bit.
J
JDavus
5.2 magnum v8
It has 156k miles no took it to a mechanic shop. Idk if they replaced the coil or not. I been second guessin the fuel pump n filter if that was It or not. That was my first guess
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
You need to put a fuel pressure gauge on the fuel rail and try and drive it to see what the pressure is.
J
JDavus
5.2 magnum v8
Coils? That ignition coil or.,....?
J
JDavus
5.2 magnum v8
Coil? Is that ignition coils or what
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
I believe he was referring to the ignition coil, yes.
Muddinginamopar
Wilkes-Barre, PA
Could very well be a plenum gasket as well... I've got my cat gutted on my 97 Dakota and I notice it idles a bit funny every once in a while, but no lack of power, that's for sure... Lights up a set of 32s with power to spare.
Sent from my pathetically slow iPhone
J
JDavus
5.2 magnum v8
I got it fixed a complete tune up intake gasket n fuel injectors n fuel pump. $$$$$
