Polishing chrome wheels
1SilverBullet2
North Dakota
2014 Big Horn 8 speed
I haven't done much detailing besides washing and a little waxing with any of my vehicles. I know the chrome clad wheels on my truck could use some polishing but I looked at mothers mag and wheel polish and it said don't use on chrome. How come? What do you guys use for a chrome polish? I'll also be polishing the front and back bumper and exhaust tips.
Sent from the howitzer
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Your "chrome" wheels are plastic. Wash them up and put a good coat of wax/sealant on them.
Jay
1SilverBullet2
1SilverBullet2
North Dakota
I know they're plastic that's why I said chrome clad. I'll try waxing them then thanks Jay
MADDOG
Out Exploring Arizona
Yeah, you don't "polish" chrome. You clean it and wax it.
lukedukem
Victoria, Tx
aren't there some guys who have removed the plastic cover and painted the rims?
Luke
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
Yes, but I can't think of where the threads are????????
Jay
Westwind1124a
Maine
2024 ZR2Hd
6.6 Duramax
mine were so bad in the spring that I had to use wheel cleaner and claybar at the same time to get all of the **** off of them. It did work though
Nobrigz808
Oahu, HI
mine had some pretty bbad water spots on them that didn't come off with normal washing. i used chemical guys heavy metal polish on a microfiber towel and very light buffing by hand... cleaned them up really nice. then topped it with a sealant.
Jonv8944s
anyone have a link to what these wheels look like without the plastic/chrome cladding on them? Sounds interesting.
Slick61
I've used Meguiar's "Plast-X" to thoroughly clean the plasti-chrome wheels... then slapped a coat of wax on them.
mcheath
Central California
Actually they are real chrome. ABS plastic is the base material, then copper is electroplated on, followed by nickel. After that the chrome plating is applied, typically in three layers.
Chrome can be applied to many surfaces with this process, which is the same method used to chrome plate steel. Plating ABS plastic gives the exact same finish but with greater longevity, no rust issues, and lighter weight.
Polish your chrome clads as you would any chrome. I've used plain old Turtle Wax rubbing compound with a buffer to remove water spots and their ordinary wax as well.
I really like the modern chrome plated ABS, no rusting like chrome plated steel always does.
1SilverBullet2
1SilverBullet2
North Dakota
Does a guy go ahead and use metal polishing on the bumpers or do I need to wax them too?
Tango111
On my 2013 which had the chrome clad wheels, I used Never-dull. worked perfectly with minimal effort. It's sold at Wal-mart
T111
Slick61
There is a downside tho... the ABS is far less impact-resistant. My Ford Edge has chrome-clad wheels... when getting the tires rotated, the tech spun the wheel & leaned it up against the wheel studs. I ended up getting a big ding in the wheel (right through to the ABS) as a reminder. And the perimeter tire-balancing weights tend to mar the finish as well.
Pull Ya
U.S. MARINE VETERAN
Cedar Creek, Tx
I think that if you need to clean anything off them that a clay bar would do a good job. I would be hesitant to use anything that is very abrasive as you might end up with lots of small scratches you have to try to polish out before you wax/seal them.
Jay
1SilverBullet2
1SilverBullet2
North Dakota
I'm gunna wash them tomorrow and try throwing some wax on them and see what they look like.
Kytow
I use blue magic on the chrome clad with great success.
Sent from somewhere with confusion.
Ftank
