Hydrasport23
I tried adjusting the headlights the other day and noticed how much less light the fogged up left headlight was putting out when compared the the right headlight. I removed the headlight and used a vacuum cleaner to pull a vacuum on the headlight housing to remove all the moisture from my left projector headlight assembly. That worked well and I even added a large desiccant bag inside the headlight assembly. The one way vents are open and I adjusted the vent covers so they are not completely shut off. The moisture is back today and it really dims the light coming from that headlight. Swapped bulbs and even bought new bulbs but the moisture on the lens is definitely reducing the amount of light. Has anyone had success clearing the headlight of moisture and keeping it from returning? The seems do not appear to be in bad shape but the moisture is coming from somewhere. The right side was giving moisture problems a year ago, but once I cleared the fog out of the lens, I've had no more problems.
Any one buy new headlight assemblies to correct the issue and if so, what brand?
